I am trying to use my low-res (1368x766) laptop with a second monitor that's 1920x1080. The choices of setting the resolution do not go any higher than that, which is causing it to be impossible to adjust it to the second monitor because I want to use it with a pen. Duplicate is hopeless,the cursor is over an inch away from the pen. Setting the second monitor to be the only one showing the desktop makes it calibrate in some programs, but is not convenient when using the keyboard and does not work in many programs. Is there any way to raise the range of resolution the laptop can adjust to?
