Low sound in Sennheiser GSP 500
Sep 7, 2018
Hi. I decided to invest in the Sennheiser GSP 500 headphones because I never had a decent gaming headset before.
My problem is that my master sound is maxed, I check the sound mixer, and the sound is too low in general and specially in the game PUBG. Ive done some searches and I found people with the same issues.
What settings should I have in the headset properties in the sound mixer? What Hz, cd/DVD/ or studio quality? Surround option on? Bass bosst? Loudness equalization?
I didnt want to spend more money on an AMP. My motherboard is a Z97X-Sli if it helps to know.
Thank you for your attention, hope you have some suggestions.
Thanks. The sound is much higher now that I connected it to the back. Its actually painful if the sound is maxed now. In the sound mixer it shows as a speaker now.
One more question, do you know if with these headphones I should have spatial sound on in the sound properties or not? And in the advanced tab shoud I have 48000 Hz, studio quality or cd or dvd quality? Or leave it as it is? Thanks
