low sound more fps in CS GO ? :O
ataedo
13
hey i have had problems with low fps in cs go(counter strike global offesive) for a month now ... when i shoot in the game my fps go from 240 to 80 which makes the game unplayable ... but today ive noticed that when i tured my sound on my headseat down way way down ... the fps didnt drop ... at least not that drasticly ... any reason for that any fix for this without losing the sound that is one of the most important things so have in the game if your trying to master it ??? ... my setup isnt that good but it should run a game like cs go pretty smoothly i think ...
Mainboard S-AM3+ GIGABYTE GA-990XA-UD3, ATX - info 109.77
Procesor AMD FX-6100, 3,30GHz, 6-Core, S-AM3+, Boxed - info 139.89
DDR3-RAM KIT 8 GB, 1600 MHz, CL9, CORSAIR Vengeance - info 53.75
Grafična kartica PCI-E 3.0 SAPPHIRE Radeon HD 7770 GHz Edition, Lite Retail, 1024MB - info 136.04
Trdi disk Samsung F3 1TB SATA2 32MB/7200 HD103SJ - info 92.62
DVD-+R/-+RW SATA LITEON iHAS122, bulk, črna - info 16.06
Ohišje Miditower COOLER MASTER Elite 334U, ATX, črna - info 36.71
Napajalnik ATX 650 Watt, THERMALTAKE Smart M650W, 650W, 80Plus-Bronze - info 68.17
How is 80 fps unplayable?
I dont personally understand that.
If it is doing that with your audio volume turned down (that sounds very weird lol) then try to invest in a dedicated sound card.
That might offload the audio processing off the cpu anyhow and might fix that
