Question Low speed on SSD in SATA 3
Oct 17, 2022
16
I have a Gigabyte GA-Q77-D2H motherboard with Sata 3, but I can't even get data speeds with it.
Speeds are around 300mb/s
I've already tested the same SSD and cable on another PC and the speed was 500ms/s.
BIOS is up to date with F2 version as well as Windows drivers.
I disabled the C6 function in the BIOS and had a slight gain.
Is there anything else I can do in the BIOS?
Sata ssd’s are slow in todays terms, I would get a nvme drive instead (definitely worth it) my sata drive runs at around 250 so consider yourself lucky! Plus what companys say a sata ssd can run at it completely crap so I wouldn’t bother trying to make it run faster, remember to defrag and don’t forget about reseting your windows
Try a different sata data cable.
Post a screenshot from crystal disk mark for this ssd.
I have tested the same/ssd in other PC and it reached 500mb/s.
Those are sata3 speeds.
On sata2 you'd be limited to ~250MB/s
It's working as supposed.
You may try updating storage driver. But I wouldn't expect it to change much.
Note: On C: drive you'll get lowered benchmark scores, because windows is reading/writing to the drive all the time.
