low speed on usb 3.0 ports while connected to usb 3.1 mobo.. lower speed than actual usb 3.0
May 4, 2018
11
I just put usb 3.1 usb mobo on usb 3.0 case, but somehow I am getting little bit lower speed than 3.0 too! about 20mbps lower than copying stuff from hdd. Why?
A 20Mbps difference for a connection protocol rated at 5+Gbps is nothing to worry about. That's a 0.4% difference at best.
Even if you meant 20MiB/s (~160Mbps), compared to the 625+MiB/s that's still not a very big drop (3.2%).
Most likely, the drop is because of limitations on the transfer rate from the HDD. In fact, the difference between SATA III & USB 3.0 is actually ~25MiB/s (600MiB/s for SATA III, 625MiB/s or faster for USB 3.0). So it's almost certain to be due to the HDD's limitations.
