tomkis90 Reputable Jul 1, 2014 401 0 4,860 Feb 2, 2015 #1 Just ran this and the results were not as I expected. Is this normal for an SSD? if not how do I fix this?
Solution USAFRet Feb 2, 2015 If that is 'normal' for that drive, that is actually 'not great'. Here are the 3 SSD's in my current main system, with that same tool and settings:
USAFRet Titan Moderator Mar 16, 2013 179,710 22,199 184,590 Feb 2, 2015 #2 What drive is it? Is it connected to an Intel SATA III port? Upvote 0 Downvote
dextermat Splendid Sep 21, 2007 4,956 0 24,960 Feb 2, 2015 #3 Hi, What's the ssd brand and model and what is your motherboard ? Upvote 0 Downvote
tomkis90 Reputable Jul 1, 2014 401 0 4,860 Feb 2, 2015 #4 MSI z97 Gaming 3. Kingston SSDNow V300 Upvote 0 Downvote
Dereck47 Splendid Jan 20, 2011 3,275 0 22,960 Feb 2, 2015 #5 Your benchmark results are normal. Advertised Read/Write speeds using CrystalDiskMark are up to 180MB/s Read and 133MB/s Write. http://www.kingston.com/datasheets/sv300s3_us.pdf Your benchmark results indicate that you are getting 97.7% of advertised Reads and 65.7% of advertised Writes. If you are looking the advertised 450MB/s Read/write speeds then you have to benchmark with ATTO. Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,710 22,199 184,590 Feb 2, 2015 Solution #6 If that is 'normal' for that drive, that is actually 'not great'. Here are the 3 SSD's in my current main system, with that same tool and settings: Upvote 0 Downvote Solution
Dereck47 Splendid Jan 20, 2011 3,275 0 22,960 Feb 2, 2015 #7 Your HyperX 3K has better advertised specs than the SSDNow v300 even though it is older. http://www.kingston.com/datasheets/sh103s3_us.pdf But yeah, the benchmarked Write speeds of the v300 are not great. Upvote 0 Downvote
