Hi,
I found same strange voltage readings (using multi-meter) on APC BX600C‑IN 600VA, 230V Back UPS.
The INPUT voltage during this test was =~ 250 volts.
1) No Load Test:
Main Mode (UPS is not in battery mode) : The output voltage is in range= 247-250 volts.
Battery Mode: The output voltage is in the range = 142-150 volts.
And transferring the UPS from battery to mains (by switching on the power supply) gives a sudden voltage spike of 411 volts and even 500 volts sometimes.
2) On Load Test:
Main Mode: Output voltage range is 245-248 volts.
Battery Mode: The output voltage is in the range = 167-170 volts.
And transferring the UPS from battery to mains (by switching on the power supply) does not show any voltage spike.
Please suggest:
Are low voltage during battery modes normal? and what does the VOLTAGE SPIKE on no load suggest? (I guess i need to measure current in this case).
Is not this spike very dangerous when somebody leaves Mains, UPS and PSU ON (but PC OFF) and the UPS goes from mains->battery->mains; sending spike to primary CAP of PSU and damaging it.
Thanks.
1) No Load Test:
2) On Load Test:
Please suggest:
Thanks.
