Low write speeds to NAS drive
BadWolf88
6
First of all, I'm not sure if this should go under storage or networking, so sorry if I've put this under the wrong section.
I have a hard drive connected to my network through my router which I can access through either the internet or through my local network. I expected the read/write speeds to drop significantly when accessing it remotely, but did not think I would take that big of a performance hit while accessing it through my home network. My router is a Netgear Nighthawk ac1900 router and the hard drive is a WD 1TB USB 3.0 drive connected through the Netgear's USB 3.0 port. I am accessing it via my Alienware 17, which also uses 802.11 ac. I am seeing upload speeds / write speeds topping around 17 MB/s and averaging around 13.5 MB/s. The files are being copied from a pair of hard drives (on my laptop) in RAID 0. I was hoping to see much higher transfer speeds.
Is this normal or do I need to reconfigure something to max out my connection speeds?
SMB is the normal file sharing protocol built into Windows. If you access it through explorer, the same as any other drive, it's probably SMB. If you do it from a web browser, it's probably HTTP.
I am about 15 feet away from my router and have line of sight - no obstructions at all. I've not checked the speeds across a cable, I will try that later today and see what I get. I'm not sure what SMB is to be honest. Networking is somewhat new to me.
Then I'm probably using SMB. I have the drive mapped through explorer and access it just like any other hard drive when I am on my home network. I only use HTTP when I am away from home.
Ok, so I just connected physically to the router and I'm getting much better speeds, right around 50 MB/s. So the bottleneck definitely seems to be the wireless. I thought I would be getting faster speeds still as I have hit 30 MB/s on multiple occasions through the internet, limited only by my ISP. Is there a better way to set up wireless mass storage that would result in higher speeds?
