Currently my system is running stable with a slight overclock of 3.65GHz. I have the issue where I am obtaining slightly lower Cinebench R15 values past this overclock and I can’t seem to find the cause. I am unsure if my generic RAM may be the bottleneck as it is not a noteworthy type of overclocking RAM as Corsair Vengeance or GSkill Trident Z. The following below are my components: -
• CPU: Ryzen 7 1700X
• GPU: ASUS Strix GTX 1070 OC
• RAM: Single stick- 16GB 2400MHz DDR4 Patriot PSD416G24002 Timings: 17-17-17-39 & Voltage: 1.2V
• Motherboard: ASUS Prime X370 Pro
• Storage: 480GB Crucial BX300
• PSU: EVGA 750W Gold
• CPU Cooler: Coolermaster Hyper 612 Ver. 2
I overclocked my system using the ASUS motherboard tweaking software and the following are the changes I made to ensure a the overclock.
1) CPU Core Ratio = 36.5
2) VDDR CPU Voltage = 1.337V
3) VDDR SOC Voltage = 1.050V from 0.900V
4) DRAM Voltage = 1.2V to Auto
5) VDDR CPU Load Line Calibration = Level 1
6) VDDR CPU Current Capability = 110%
7) VDDR CPU Power Duty Control = T. Probe
8) VDDR CPU Power Phase Control = Optimized
9) VDDR SOC Power Phase Control = Extreme
10) Performance Core Boost = Disabled
11) Global C-State Control = Enabled
My Cinebench R15 score was 1582 for the CPU and CPU Single thread was 147. Using the bench system in CPU-Z ID, my single thread score was 407.9 and multi thread score was 4489.3. My case seems to have sufficient ventilation as after a 1 hour of Prime 95 temperatures are reading 65 degrees celsius. Now sending up my CPU Core Ratio = 37 (3.7GHz) and adjusting VDDR CPU Voltage = 1.345V whilst keeping everything the same; My Cinebench R15 score was 1531 while CPU-Z ID speaks differently with an increase of 421.4 for CPU Single thread and 4554.0 for CPU Multi thread. Any assistance as to what the problem might be would be greatly appreciated because I don’t want to damage anything on my system trying to go above the 3.65GHz.
