[SOLVED] Lower results than World's average in Firestrike/TimeSpy
insolito
27
Hello, I'm trying to benchmark my new hardware:
CPU: AMD Ryzen 9 5900x
MB: ROG Strix x470-F Gaming
GPU: ROG Strix 6800XT LC OC
RAM: 2x8GB Corsair 3000Mhz @3200Mhz
But I'm getting below average results, like in Fire Strike 32671 points. World's Average is 37484 points.
There is my results:
TimeSpy: https://www.3dmark.com/3dm/57101353
FireStrike: https://www.3dmark.com/3dm/57104355
What could be the cause for these low score? Thanks in advance!
D
Just did a fresh install and got better numbers, 😀
Now with a fresh install the userbenchmark test is complete: https://www.userbenchmark.com/UserRun/38789701
But i dont know why it reports "Performing below potential (54th percentile) "
Yeah the OS fresh install is always best. Grats on the score bump. As for userbenchmark... you'll get that "performing below potential" until you OC your GPU. I got the same... and once I OCed it started showing the "performing way above expectations." https://www.userbenchmark.com/UserRun/38137610
Happy gaming!
make and model of the psu?
cpu/gpu temp?
fresh os install?
Gigabyte 750W 80 Plus Gold Modular - G750H
CPU Temp 68~70 C / GPU Temp 50~55 C
Didnt make a fresh OS install, but Windows 10 get it to work immediately, also i had reinstall chipset and gpu drivers
Also i using the lastest bios available updated with AMD AM4 AGESA V2 PI 1.2.0.0
Can the resolution or the refresh rate influence these results? My display is set to 2560x1080 @160hz
"Average" is average for the hardware, not average for the hardware at a specific overclock. In a population that is going to have a lot of overclockers, the average stock configuration is going to be below-average.
And yes, install Windows properly. I guarantee you most of the people serious about overclocking and getting better scores aren't simply slapping their old OS install onto their new hardware to cut corners. Anything worth doing is worth doing right.
TimeSpy: https://www.3dmark.com/3dm/57101662
Where are you getting this "World's Average" from? Your 32k Firestrike shows 99th percentile... and so does my 35k. https://www.3dmark.com/fs/24586563
BTW, both your links are for Firestrike.
This too. ^
Problem #1
Problem #2, comparing your system to those that have been overclocked, tweaked and optimized for that particular test
... and this. ^
Reactions: insolito
My bad, updated, TimeSpy link is https://www.3dmark.com/3dm/57101353
i am getting from the 3DMark program after the test finish, it doesnt show in the result link:
Ok... Yeah, that 16k is 20% less than my 20k https://www.3dmark.com/spy/17188357 but again you're still in the 99th percentile and it could be the GPU? I don't know jack about AMD and how that card compares to the 3090 but that would be my first guess. But then again both your CPU and GPU scores are lower than mine... so maybe it's the overclock/clock speed differences.
Also, your memory appears to be running a little slow for a premium build.
Ahhh yeah... this too.
Ok, I know what you're talking about now. But as others have said... a lot of it is coming from those that have serious OCs on their rigs with all kinds of tweaks and optimizations... and maybe even some liquid nitrogen.
Anyway, for me I see "99th percentile" and I'm good with it... it's really nothing to stress over IMO.
Reactions: insolito
We need to get a completed test. Something's going on with your GPU.
Try this - reset all BIOS tweaks/overclocking and GPU tweaks/overclocking to their defaults and re-run userbenchmark (and the other benchmarks).
In Userbenchmark, a relative performance above 50% is good and above 70% is a finely tuned system. 'Relative' performance is NOT the benchmark score. It is the percentage listed in the component description.
See here - View: https://imgur.com/0O5Ojgk
Reactions: insolito
You have completely different hardware their no way to compare the 2 PC's and say 1 is not running right.
I never said his PC wasn't running right... I'm just trying to point out differences why his scores are lower... which seems to be his question... and also pointed out he's STILL in the 99th percentile.
  1. GPU
  2. Memory speed
... and as others have said, his system probably isn't running the same tweaks and optimizations that the premium scores are... and my system isn't either.
What a world we live in... people in the 99th percentile on 3DMark and complaining about it saying there's something wrong with their PC. Personally I don't think there's anything wrong with OP's PC... I just think his hardware isn't as good as mine and the rest of the PCs that scored higher.
Reactions: insolito
OP, don't bother about those numbers. Benchmarking at today is huge pissing contest. Up to tens of grands worth equipment - machines built only to beat particular benchmark with specially prepared components, liquid nitrogen cooling etc. etc. It is not worth to involve yourself in this if you don't have spare 15-25 grands and ambitions of Kardashian (yes, pun intended). If your machine is stable with default XMP/DOCP parameters for your RAM, consider yourself lucky. I would only recommend to consider MOBO upgrade to X570 or good B550 board. And RAM upgrade to 3600/CL16 or 4000/CL18 modules in near future. Current MOBO and RAM does not work with full potential of your CPU.
+1 Totally agree.
... and therein lies the problem.
TimeSpy: https://www.3dmark.com/3dm/57116392
FireStrike: https://www.3dmark.com/3dm/57117259
Userbenchmark: https://www.userbenchmark.com/UserRun/38789701
And now i am close to the Average tests (using same cpu and gpu):
Need to run that test again...
Happy gaming!
Reactions: insolito
Don't worry about the 'below potential' tag. Userbenchmark wants you to test and test again, and hit their links for sponsors, and buy stuff from their links.
Like I previously said, anything above 50% is good. The higher scores are probably tweaked/overclocked settings and not applicable as a good comparison.
