Hey guys,
I'm a pro VALORANT player in MENA region, and I wanted to build a new PC, and I was looking to achieve the lowest end-to-end system latency, I already own the 240hz XL2546K and high tier Esports-ready gear.
But I also will play, The finals, Apex Legends, CS2, GTA5, etc
I've always heard Intel has the lowest input lag and much snappier than AMD, but since the X3D versions came out ppl been saying everything latency-wise is fixed specially the 7800X3D since it has only 1 CCD, and there are no 2 CCDs like before that need to intercommunicate and wait to pull the requests/actions, etc.
So I'm stuck between these 2 options.
Intel Setup:
I7 14700K
MSI VENTUS 4070 3X E OC 12G
GIGABYTE AORUS Z790 ELITE AX DDR5
Corsair Vengeance 32GB 6000MHz (there's one AMD EXPO CL30 and there's another one Intel XMP 32/36, Idk if the AMD is compatible with XMP motherboards.)
DeepCool LS720 360mm
WD SN850X 1Tb SSD
AMD Setup:
R7 7800X3D
GIGABYTE AORUS B650 ELITE AX DDR5
Corsair Vengeance 32GB 6000MHz AMD EXPO CL30
WD SN850X 1Tb SSD
I really wanna know which one has the lowest input lag and snappier than the other.
Thanks in advance <3
Intel Setup:
I7 14700K
WD SN850X 1Tb SSD
AMD Setup:
R7 7800X3D
WD SN850X 1Tb SSD
