Lowest power multi monitor setup for Ubuntu
trialandimprovement
Commendable
Jul 5, 2016
12
Hello everyone, first time poster but long time lover of this website.
My aim is to build a silent (fanless) many-monitor PC for software development. Ideally I'd love 8 or so monitors but right now I'm aiming for 4. After lots of trial and improvement I'm almost there, my only problem are graphics cards. I know I need several to achieve this many video outs, but every fanless card I've tried seems to get very hot. With 2 I get heat problems, I don't know how I'm going to get 4 right next to each other. I have even compromised and added some case fans with little benefit. I don't want to use external graphics cards to keep it neat. I'm not using the integrated CPU graphics because they don't seem to play well with graphics cards. Due to the layout of my case, the heat sinks on the cards face downwards, which I assume isn't normal and can't be helping.
So far I have identified the following potential chipsets:
- HD 5450 (Tried the XFX AMD 1gig: heat sink gets super hot - is this a particularly hot board? Would the ASUS ATI be better; it seems to have a cooler heat sink?)
- NVS 300 (Tried this, heat sink is cooler than the HD 5450 but pretty hot. Sadly having driver problems with Ubuntu. Display sometimes freezes with only mouse moving with open source driver; no mouse at all/sometimes won't boot with NVidia driver.)
- GT730 (Have not tried this)
Are there no cards under 10W max output? Do different boards with the same chip have different heat output? Is what I am aiming for impossible?
I don't want to do 3D, I don't want to do gaming. I just want the lowest possible power that will support lots of screens. No heat sinks would be ideal!
Motherboard: ASRock Z77 Pro4-M
CPU: I5-3570K 3.40GHz
Assorted displays
Thank you!
Thanks so much for the reply. Looks like an interesting product, especially the 4 outputs.
According to this thread, http://www.tomshardware.co.uk/answers/id-2610626/screens-working-sapphire-w4100-video-card.html it can only support 4 screens with DisplayPort connections, not over DVI or VGA. Is that correct because none of my current screens have DisplayPorts unfortunately?
I noticed a newegg review saying the fan was a bit loud. Have you used this card yourself, is that fair? My main aim is to go low noise / fanless ideally. Regarding the power output, I've seen it listed as 50W ie >10W/monitor. It seems a bit higher wattage than those cards I mentioned, or did I miss something? I appreciate it supports much higher resolutions than those old cards.
It should run several monitors off DP and several with adapters. I don't think any of the cards you are looking at in your post can run 4 displays.
Don't know how loud that card is really, but it may be a bit loud. You can't keep heat down with dual video cards in a system though unless you build it on a ULV format like a rasbery PI but that is more for display than working with.
You're right, none of the cards I mentioned can support 4 displays. Sounds like this is going to be tricky. Thanks for recommending that card, I'm going to check it out some more. I think I'll look into USB graphics adaptors too.
