[SOLVED] 'LuminonCore IDDCX Adapter' breaks my NZXT CAM!
gamerbrehdy
320
29
10,790
Hi,
I own an NZXT Kraken Z53, and I use NZXT CAM to control it. Recently, the cooler showed that the GPU is running at unbelievable temperatures, and it seems it fails at some decimal point( 26,9 degrees displays as 269 degrees). Checking pc monitoring shows that my gpu is running at 139000MHz!!! If I click on it in CAM, the window shows 2 GPU's: my gtx 1060 and the LumininCore IDDCX Adapter. After some research, this adapter seems to be something related to usb-displays, like the display on my CPU-cooler.
Is there (if anyone knows) a way to remove the LuminonCore readings from my NZXT CAM?
