[SOLVED] m.2 cooling
Nov 6, 2021
I'm soon getting another m.2 and I'll no longer use the one I have currently. would it be best to buy another heatsink or could I reuse the old heatsink from the old m.2?
huh, i can't seem to get it to work at all, might be because of compatibility issues? (ie, integral m series isn't on Asrock's list of compatible ssds for ab350m pro4 mobos)
https://www.asrock.com/mb/amd/AB350M Pro4/index.asp#Specification
1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Matisse, Picasso, Summit Ridge, Raven Ridge and Pinnacle Ridge) or Gen3 x2 (16 Gb/s) (with A-Series APU and Athlon series APU)**
**Supports NVMe SSD as boot disk
Possibly you were using the wrong M.2 port?
NVMe is only supported in the M.2_1
Physically disconnect all other drives, and try the OS install on this new drive in the...
m.2 heatsinks are largely marketing. Go ahead and use the old one if it fits.
What are the rest of your specs?
What is the make/model of the m.2 devices in question?
Under normal operations which is small random i/o(some 90% of the time), there is no heat issue.
It is sustained sequential processing of 30-60 seconds where a m.2 device can heat up and throttle. That does not happen often, perhaps during a virus scan.
just updated my 'about me' to list most, if not all, my specs. I'll list them here in case you cant see it:
Ryzen 7 1700
Sapphire RX 570 4GB
Corsair Vengeance 2666 MHz 2x8GB
Asrock AB350m - Pro4
Integral M Series 128GB M.2 -> WD_BLACK SN850 500GB M.2
  • 2TB HDD
  • 500GB HDD (forced to use as 'boot' drive as mobo doesn't have ssd boot option)
Aerocool Cyclon 600W 80+ white (saving money for an upgrade)
The ssd i'm currently using is the integral m series, and the new ssd will be the wd black sn850 which should be arriving soon. As far as i know, my current ssd doesn't throttle at all, the only bottlenecks are its sequential w/r speeds
Physically disconnect all other drives, and try the OS install on this new drive in the M.2_1 port.
