Ok, CSM is legacy BIOS - so you want that disabled.
You also want Fast Boot enabled.
That should dramatically change your boot times..... but you have to configure your BIOS *before* you install your OS - so you'll probably have to reinstall your OS.
I'm not sure with your soundcard, but it'll relate to the which slots share bandwidth. Beyond that, it's a little outside of my where I'd be comfortable going into detail (I'm smart enough to know when I'm not smart enough on a specific topic).
The PM961 is technically an OEM device, so Samsung are under no obligation to release a driver - but I believe they did on their Enterprise website. Let me track it down for you.
As for the hanging around, you don't have to. Stop by when you can - there's no required timeframe here, people help if/when they can.
nabdone69 :
Also, I am completely new to forums so I don't know if I should stay on this page or go about my business and check back later.
FYI, my sound card is on the most bottom slot....
Did you just move it there? Or is that where it's always been? The PCIe x1_1 slot would be where you want it to be.... is suspect it's in x1_3 which, on some older boards shared bandwidth elsewhere.
Looked for the PM961 driver, but unfortunately Samsung don't list it. They list their 960 Pro, which I would assume uses the same driver though..... (don't know 100% though). you probably won't need it right now, and Samsung Magicinan should find it for you inside Windows.
Fast boot = enabled
CSM = disabled
And you should see the speeds you're anticipating.
Move your soundcard to another PCIex1 slot and all should be fine there too.
