Hello all,
I am still running Win7 on my main Pc at home xD
I am looking to upgrade/ dual boot Win 11 just because some apps do not work anymore.
My mobo is and old Asus Sabertooth Z77,
what i am looking to do is to use https://www.skroutz.gr/s/38120052/A...e-syndesi-Type-C-90DD02N0-M09000.html#similar
with https://www.skroutz.gr/s/27703325/S...W.html?product_id=123048847&sponsored=listing. Or something along those lines.
My question is if it is possible to connect this on my mobo through usb3 or sata on the back?
It really matters to me for this to be portable as i will be able to hook it up elsewhere if anything goes wrong with the current system. I would just use the internal sata instead if portability was none of my concern.
Should i just use a regular sata ssd with a case?
What is the best way to do this and the most budget friendly?
It's been a long time since i have had any sort of engagement with all of this and i am kinda lost!!
Thx
Thx
