Hello everyone. I bought a pre-built gaming PC about two years ago and have made some upgrades to it since then. I'm not incredibly computer savvy but I'm not a complete dummy either...maybe just a little, I'd appreciate some help.
The motherboard is a Gigabyte H110M-S2H-CF (This is the model number I'm seeing from the program CPU-ID/CPU-Z, though I've never been able to find the "CF" part of that model number anywhere on the internet and I have no idea what it is) So I currently have windows on my HDD and one additional SATA SSD drive with some games on it. After clogging up the PC with random crap for two years I have the most annoying microstutter in almost everything from browsing the internet to gaming, to simply moving windows around. I'd like to do a fresh install of windows to hopefully eliminate this issue. I'm having trouble figuring out if my motherboard is compatible with an M.2 drive so I can get one and start over by installing windows there. I have looked at the manual for the mobo (minus the "CF" at the end of the model number since I can't find that anywhere) and this is what I see that i believe is what I should be looking at...
Expansion Slots
1 x PCI Express x16 slot, running at x16 (PCIEX16)
(The PCI Express x16 slot conforms to PCI Express 3.0 standard.)
2 x PCI Express x1 slots
(All of the PCI Express x1 slots conform to PCI Express 2.0 standard.)
Storage Interface
Chipset:
4 x SATA 6Gb/s connectors
I think this means I can't use an M.2 without getting a new motherboard? Since I don't see M.2 anywhere? But I'm not 100% sure. So i'd really appreciate it if someone could confirm that for me. Thanks so much.
Expansion Slots
Storage Interface
Chipset:
