[SOLVED] M.2 Screw Help
Mar 15, 2018
I built my pc a while back and recently got a nvme m.2 ssd. I checked the manual to figure out how to install it and it talks about unscrewing a screw in one of the three holes on my motherboard (Asrock ab350 pro4) but my motherboard doesn't have it. I've looked around for the m.2 ssd screw but I can't find it. Is there any way I'd be able to buy the screw from somewhere?
Same situation. A 2mm screw or M.2 was needed for my motherboard.
I had expected the Samsung EVO gumstick to come with the hardware needed. I recovered proper sized M.2 screws on an ACER T100 and used one. The Acer chassis showed screw-head markings 2mm and 2.5mm for assembly personnel.
