[SOLVED] M2 SSD's actual speed is a lot lower than test results
Sep 26, 2019
Hi, I have Samsung EVO 970 500GB SSD. Its' speeds are advertised as 3500MB/s reading and 3200MB/s writing.
But when I try to copy or move files within my computer or between external drives, I see 100MB/s transfer speed at best.
Also, when I run tests through Samsung Magician or CrystalDiskMark; I get following results
What can I do about it, or is it normal?
Thanks in advance!
USAFRet
114,592
2,120
157,240
18,635
This is absolutely normal.
Speed is dictated by the slowest device in the chain.
An external HDD, or the USB interface, or over your LAN...all much slower than that actual drive.
You can't read from or write to an HDD faster than that HDD can do, no matter what your SSD is capable of.
USAFRet
114,592
2,120
157,240
18,635
Sep 26, 2019
Thanks for the answer, I'm also curious about one more thing though. This slow transfer also occurs when I copy a file from my SSD directly into the same SSD. Like, even if I create a copy of a file in the same exacty directory; the copying progress is slow, ranging between 20-400MB/s, nowhere near 3000MB/s.
Is this also normal?
