Question Connecting DeathAdder V3 Pro Mouse to a Mac Mini M4 ?
kisserik93
47
Hi everyone!
I’d like to use a DeathAdder V3 Pro Mouse with my Mac Mini M4, but the computer doesn’t have a USB-A port. I see two options: either I buy an adapter and use the original cable with the DAV3Pro, or I get a USB-C to USB-C cable (I was thinking of an official Apple cable) and use the mouse that way. Which solution do you think is better? I couldn’t find a Razer USB-C to USB-C cable online.
Thanks!
If I was in your shoes and had the funds, I'd get this;
https://satechi.net/landing/new-stand-and-hub-m4-mac-mini
and call it a day but you should look into any USB Type-C cable and you should be fine.
I slipped a little with the answer. Thank you very much!
Will it cause any problems if I just replace it with a Factory Apple cable? There are factory Apple cables at home that can handle 60W and 240W.
Thank you very much for the dock recommendation, I will buy it, but only during some sale,
