M4A88T-M LE supported graphics
ethriuz69
13
i have a M4A88T-M LE motherboard and AMD Phenom II X4 prcecessor. i want to know which graphics card would support?
im planning to use GTS 450 is that supported? or more? can you suggest Graphics card that compatible to my specs?
here is my currently specs:
Asus M4A88T-M LE
NVIDIA GeForce GT 440
DDR3 4gb
HD 465gb
My friend your board has 1 x PCIe 2.0 x16 so any modern GPU is going to fit.
Do you want your PC for gaming because if you do I have serious concerns about your choice of GPU.
What's your budget and what country will you be buying from?
Do you not have the budget to get a better card than a GT 450? it's pretty weak.
When you say add 4GB RAM do you mean use your old one and get another to make 8GB?
The answer would be yes but you need the "exact" and I mean "exact" same model RAM stick otherwise it won't be properly compatible.
