M4A89GTD Pro/USB3, no post tried everything on forums
Draknier
Hi i just put together my desktop and i cant get it to post with the on board video or the graphics card tried 1 stick of ram tried CrashFree BIOS 3 had no sound since the case has no speaker and the on board audio dosent seem to work disconnected and reconnected every thing bulled the motherboard battery, disconnected the hard drives still the monitore say no signal no matter if i use the vga cable or the hdmi cable memory test ok on board memory test light when depressed to run will go trough its sequence and continue to flash. any ideas or suggestions at all would be great specs bellow.
motherboard=Asus M4A89GTD PRO/USB3
Power supply=rocketfish rf-900WPS
Memory= Corsair TR3x6g1600C8D
case= Antec twelve Hunred ATX
CPU= AMD Phenom 2 black 6core
CD=LG Blue ray/dvd burner
Hard drives=32gb solid state/ 1.5t Seagate
Graphics Card= XFX HD 5970 Black Edition
any help would be great thanks
Go here:
http://www.tomshardware.com/forum/261145-31-perform-steps-posting-boot-video-problems
work through the list..WORK, not read!!!
If you are still having problems we will try to help!
Two things that do stand out from your list of component:
PSU -- Rocketfish??? never heard of it.. could be an issue
Memory --- You have a triple channel kit and your Motherboard only supports Dual channel, :You can put all three sticks in, but the motherboard will then run it all at single channel speeds. You would be better off to only use two sticks of the ram( in similar colored DIMM sockets), then you would at least be running in dual channel mode..
Good Luck!
Go here:
Good Luck!
In that case, unless i could find a GOOD review from a site like JonnyGuru.com or hardocp, I would definitely recomment a PSU from Corsair, Seasonic, XFX, Antec earthwatts, PCP&C, or possibly OCZ, in the 650-850 watt range, 80+ certified, with APFC. :bounce:
Thanks for the link clarkjd turned out to be two things on the list one was the power for the cpu (forgot to plug it it) feel like a idiot and the other was the memory, got it to post with one ram stick.
ya know..i have the same board with 16gb of memory , corsair vengence, running at 1600mhz, 1090t, hd5770...there was a bios update (beta) for the x8 and i updated it thinking i was going to get the x8 but i decided the 2 extra cores wasent worth the price....only downside, ram would only run at 1333mhz...at 1600 bsd every time windows tried to load (7 64bit).FYI
