M5A78L-M/USB3 flashing BIOS problem
kanatsky
Hello everyone,
I've bought the Asus M5A78L-M/USB3 in combination with a AMD FX-4100.
This CPU requires the latest BIOS firmware to run properly.
http://support.asus.com/cpusupport/cpu_support_right_detail_mkt.aspx?SLanguage=en&p=1&m=M5A78L-M/USB3&cpu=FX-4100%28FD4100WMW4KGU%29,3.6GHz,4C,95W,rev.B2G,AM3+&pcb=ALL&sincebios=0411&memo=
The current version is 0403 (15/08/2011), so it's needs to be updated to 0603 (18/10/2011). When I put the rom file on a USB flash disk, start EZFlash and select the new rom I get the following message:
"ROM ID in the file is incompatible with existing BIOS" ..
Could someone explain to me why I can't flash/update the BIOS?
When I try version 0411 (06/10/2011) I get the same error :(
The USB flashdrive is a FAT32 type and all the roms are extracted (placed as .ROM files on the drive).
Thank in advance
EDIT: I've renamed the ROM file to a max of 8 characters but this still gives me the same message in EZFlash.
tackford
kanatsky,
I have exactly the same problem, same error message, etc with both an -LX and -LX Plus mb.
I just now submitted a "Technical Inquiry" with ASUSTek about the problem - just before finding your question here.
Have you had any luck finding a solution? If not, I will share whatever response I receive from them (they promise a reply within 48 hours.
Tack
tackford
Follow up-
ASUSTech responded with instructions within about 6 hours. The proper BIOS ROM depends upon the serial number it seems. My M5A78L-M LX Plus needed the 0402 BIOS, nothing later would work. The M5A78L-M LX required the 0602 BIOS ROM in spite of being earlier manufacture than the LX Plus, go figure. Both boards flashed and now work fine.
I suggest that you file a Technical Inquiry with ASUSTek support, providing the serial number of your board.
Good luck.
Tack
Multisniper barret
Also worked for me on my LX PLUS.
