O Okura Reputable Oct 21, 2014 8 0 4,510 Jan 27, 2015 #1 Right now I have 3 fans in my case. One in the front, top, and back. Is there anyway I could connect a 4th fan to this motherboard?
Solution B B boosted1g Jan 27, 2015 That board has 5 fan headers on it including cpu. You can hook the rear fan to the second cpu header if you don't have a fan hooked to it, then they will spin at the same speed. Otherwise you can always buy a Y cable.
scout_03 Titan Ambassador Feb 18, 2010 30,587 324 107,640 Jan 27, 2015 #2 you could cpu opt one for it or a y splitter for 2 fans on the same connector what is you case name and model and where the fan are set in . Upvote 0 Downvote
B boosted1g Titan Jun 12, 2013 14,847 9 81,765 Jan 27, 2015 Solution #3 That board has 5 fan headers on it including cpu. You can hook the rear fan to the second cpu header if you don't have a fan hooked to it, then they will spin at the same speed. Otherwise you can always buy a Y cable. Upvote 0 Downvote Solution
