I'm trying for a mild OC on my M5A99FX Pro R2.0 / AMD8350 combo.
I'm able to raise the CPU Freq to 4.5 by manually setting the multiplier to 22.5 The machine boots up fine, but fails Prime95 right away. Must be time to raise the vcore, right? Here's the problem:
No matter what value I try to use for the CPU voltage, the computer refuses to post. If I set the voltage manually, it wont boot. I've tried values between 1.34 and 1.5 --nothing outside that range. In order to limit variables, I even reset the board to factory defaults, set the clock time and /only/ adjusted the CPU voltage. Refuses to post.
Also, I have tried it with Turbo mode and all power saving features turned off.
Any thoughts? Am I missing anything obvious? Heat is not an issue. I'm failing before I even have a chance to get sweaty.
The components:
Antec Nine Hundred Case with tons of airflow
Asus M5A99FX Pro R2.0
AMD8350 with Cooler Master Heat Sink
G.Skill Ram F3-2400c10D-16GTX
Old old old Saphire video card 256mb
I'm sure my problem is a dumb new guy problem. Hoping one of you fine folks will take pity and boot me in the right direstion.
-Aaron
P. S. If I have posted this on the OC.net forum as well. Responses have been minimal, so I have choosen to try my luck here. Hope this does not offend anyone.
The components:
-Aaron
