Mac compatible monitors (Help!)
Aubzzz
Hey guys,
I have a 2015 macbook pro retina 13" (base model) and I'm looking for a 21.5" external monitor.
My budget is $200. My use is light gaming + school + multimedia.
1. Are most monitors mac compatible?
2. Are these 2 mac compatible?
http://www.newegg.ca/Product/Product.aspx?Item=N82E16824236205
http://www.amazon.ca/BenQ-GW2265HM-21-5-Inch-LED-Lit-Monitors/dp/B00KYCSRQI
3. Any other suggestions?
Thanks in advice
If you have an (Retina) MacBook Pro it has an HDMI out. Any monitor or TV with an HDMI input will work. Both monitors above will also work because they have HDMI input. You will need to purchase an HDMI cable separately if you don't have one. Most monitors only come with DVI/VGA cables. HDMI cables are only...
If you have an (Retina) MacBook Pro it has an HDMI out. Any monitor or TV with an HDMI input will work. Both monitors above will also work because they have HDMI input. You will need to purchase an HDMI cable separately if you don't have one. Most monitors only come with DVI/VGA cables. HDMI cables are only like $5 bucks or less depending on the length on Ebay. Link Below.
http://www.ebay.com/itm/HDMI-Cable-5ft-1-5M-for-Bluray-3D-DVD-PS3-HDTV-XBOX-LCD-HD-TV-DVR-NVR-1080P-/191670100247?hash=item2ca06da117:g:Qc8AAOSw5VFWJgln
