B Bongo S Honorable May 2, 2013 2 0 10,510 May 2, 2013 #1 My Mac Mini works perfectly via HDMI into a Samsung UA55D800 LED TV but when I plug it into the Samsung UA55ES7500R LED TV I get nothing. What is the difference between these two LED TV's?
COLGeek Cybernaut Moderator Apr 6, 2009 59,741 5,400 184,340 May 2, 2013 #2 Try another HDMI cable. Also, verify that the HDTV is set to the proper HDMI input port. Is your Mac Mini also connected to another display? Upvote 0 Downvote
B Bongo S Honorable May 2, 2013 2 0 10,510 May 2, 2013 #3 Tried serious HDMI cables and verified Samsung on correct input. Mac mini not connected to any other display Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 59,741 5,400 184,340 May 2, 2013 #4 Do you have another display you can test with? What model of Mac Mini are you using? Upvote 0 Downvote
