I have an old A1181 Macbook Core 2 Duo Running El Capitan with 2gb of Ram.
When my macbook dies, and sometimes even after a proper shutdown, It doesn't boot successfully on the first try. It turns on and immediately shuts off without even turning on the LCD. But when I press the power button a second time, it boots perfectly fine. To me this points to a broken capacitor on the logic board that isn't building a charge properly.
Also, the battery is very iffy. If I put any stress on it (Usually happens while streaming steam games from my Desktop) as soon as it starts to get below 30 or 20 percent, it will report that it is running on reserve battery, and will shut down seconds after. But if Im just doing schoolwork or browsing the web it goes until 1%.
I just want to know if I should be worried and if I can fix either of these issues.
Thank you so much!
Thank you so much!
