• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question Macbook Air 6,1 2014 running incredibly slow (Diagnostic Attached)
Mar 25, 2020
6
I reformatted, High Sierra was put on it. I upgraded to Catalina to see if it would perhaps fix the problem. Slow, very slow. Attached below is a EtreCheck Diagnostic. Any help would be appreciated, I am tech savvy but I am not too knowledgeable at MAC. (Windows is my forte)
EtreCheckPro version: 6.2.6 (6C020)
Report generated: 2020-06-23 15:14:57
Download EtreCheckPro from https://etrecheck.com
Runtime: 11:51
Performance: Poor
Problem: Computer is too slow
Description:
MacBook is incredibly slow, even after reformatting the HD.
Same problem on High Sierra and now Catalina.
Major Issues:
Anything that appears on this list needs immediate attention.
No Time Machine backup - Time Machine backup not found.
Stuck iCloud - This machine has a large number of pending iCloud transfers.
Poor performance - EtreCheck report shows poor performance. This is unusual.
Software performance problems - Software seems to be causing performance problems.
Minor Issues: None
Hardware Information:
MacBook Air (11-inch, 2013 - 2014)
MacBook Air Model: MacBookAir6,1
1.4 GHz Dual-Core Intel Core i5 (i5-4260U) CPU: 2-core
4 RAM - Not upgradeable
BANK 0/DIMM0 - 2 GB DDR3 1600
BANK 1/DIMM0 - 2 GB DDR3 1600
Battery: Health = Normal - Cycle count = 112
Video Information:
Intel HD Graphics 5000 - VRAM: 1536 MB
Color LCD 1366 x 768
Drives:
disk0 - APPLE SSD SD0128F 121.33 GB (Solid State - TRIM: Yes)
Internal PCI 5.0 GT/s x2 Serial ATA
disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk0s2 [APFS Container] 121.12 GB
disk1 [APFS Virtual drive] 121.12 GB (Shared by 5 volumes)
disk1s1 - k*** Data (APFS) [APFS Virtual drive] (Shared - 5.86 GB used)
disk1s2 - Preboot (APFS) [APFS Preboot] (Shared - 85 MB used)
disk1s3 - Recovery (APFS) [Recovery] (Shared - 529 MB used)
disk1s4 - VM (APFS) [APFS VM] (Shared - 1.07 GB used)
disk1s5 - kat (APFS) (Shared - 11.00 GB used)
Mounted Volumes:
disk1s1 - k*** Data [APFS Virtual drive]
121.12 GB (Shared - 5.86 GB used, 102.74 GB available, 102.45 GB free)
APFS
Mount point: /System/Volumes/Data
disk1s4 - VM [APFS VM]
121.12 GB (Shared - 1.07 GB used, 102.45 GB free)
APFS
Mount point: /private/var/vm
disk1s5 - kat
121.12 GB (Shared - 11.00 GB used, 102.74 GB available, 102.45 GB free)
APFS
Mount point: /
Read-only: Yes
Network:
Interface en0: Wi-Fi
802.11 a/b/g/n/ac
Interface en2: Bluetooth PAN
Interface bridge0: Thunderbolt Bridge
iCloud Quota: 29.65 GB available
iCloud Status: 96 pending files
System Software:
macOS Catalina 10.15.5 (19F101)
Time since boot: Less than an hour
Notifications:
EtreCheckPro.app
one notification
Security:
System Status
Gatekeeper: App Store and identified developers
System Integrity Protection: Enabled
Antivirus software: Apple
System Launch Agents:
[Not Loaded] 16 Apple tasks
[Loaded] 191 Apple tasks
[Running] 106 Apple tasks
System Launch Daemons:
[Not Loaded] 35 Apple tasks
[Loaded] 192 Apple tasks
[Running] 110 Apple tasks
Launch Daemons:
[Loaded] com.apple.installer.osmessagetracing.plist (Apple - installed 2020-03-26)
Time Machine:
Time Machine Not Configured!
Performance:
System Load: 13.98 (1 min ago) 53.97 (5 min ago) 34.18 (15 min ago)
Nominal I/O speed: 1.99 MB/s
File system: 120.36 seconds (timed out)
Write speed: 233 MB/s
Read speed: 359 MB/s
CPU Usage Snapshot:
Type Overall
System: 67 %
User: 14 %
Idle: 20 %
Top Processes Snapshot by CPU:
Process (count) CPU (Source - Location)
system_profiler (2) 37.22 % (Apple)
WindowServer 19.74 % (Apple)
EtreCheckPro 13.60 % (Etresoft, Inc.)
kernel_task 4.22 % (Apple)
ps (5) 1.20 % (Apple)
Top Processes Snapshot by Memory:
Process (count) RAM usage (Source - Location)
system_profiler (2) 543 MB (Apple)
EtreCheckPro 464 MB (Etresoft, Inc.)
mds_stores 79 MB (Apple)
accountsd 61 MB (Apple)
kernel_task 53 MB (Apple)
Top Processes Snapshot by Network Use:
Process (count) Input / Output (Source - Location)
mDNSResponder 62 KB / 30 KB (Apple)
apsd 8 KB / 19 KB (Apple)
netbiosd 5 KB / 5 KB (Apple)
SystemUIServer 0 B / 64 B (Apple)
AudioComponentRegistrar 0 B / 0 B (Apple)
Top Processes Snapshot by Energy Use:
Process (count) Energy (0-100) (Source - Location)
system_profiler (2) 13 (Apple)
WindowServer 7 (Apple)
trustd (3) 0 (Apple)
bluetoothd 0 (Apple)
usbd 0 (Apple)
Virtual Memory Information:
Physical RAM: 4 GB
Free RAM: 551 MB
Used RAM: 2.04 GB
Cached files: 1.42 GB
Available RAM: 1.96 GB
Swap Used: 0 B
Software Installs (past 30 days):
Install Date Name (Version)
2020-06-23 SU_TITLE (10.15.5.1.1.1590622861)
2020-06-23 iTunes Device Support Update (1.0.0.0.1.1558653107)
2020-06-23 Safari (13.1.1)
2020-06-23 iTunes (12.8.2)
2020-06-23 Security Update 2020-003 (10.13.6)
2020-06-23 macOS Catalina (10.15.5)
2020-06-23 MRTConfigData (1.62)
2020-06-23 XProtectPlistConfigData (2123)
2020-06-23 Gatekeeper Configuration Data (181)
Diagnostics Information (past 7-30 days):
2020-06-23 14:17:28 syncdefaultsd Crash
Executable: /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd
Details:
dyld3 mode
*** Terminating app due to uncaught exception 'NSInternalInconsistency
Exception', reason: 'Unexpected syncIdentifier(30) for app:accountsd/0
x7fd998e4eb20'
terminating with uncaught exception of type NSException
abort() called
End of report
