Hi all,
So due to change of work position I've also changed the laptop from Lenovo t15 to MacBook Pro M2 which I'm trying to run with an Anker USB-C hub for dual monitors, USB devices and LAN cable.
Everything works as expected except the second monitor which is only available as a duplicate screen of first external monitor (I suppose thats the default behaviour without any change of settings).
When I check my display settings the second monitor is not on the display list... If I unplug it from the hub and plug it in via HDMI directly into the MacBook it shows in the settings and works as extended display. On the old lenovo everything worked out of the box as it is supposed to with this Anker hub.
Any ideas?
Monitors are:
ASUS VG248QE
AOC 24G2
Any ideas?
Monitors are:
ASUS VG248QE
AOC 24G2
