Macbook Pro Problems
Tydeocean
85
My early 2011 Macbook Pro has been having this problem for a while where it will randomly randomly start activating gesture when I ever even touched the trackpad, while it is doing this my pointer to going crazy all over the screen and making it very hard to control. I also think that their is an issue with the keyboard possible because one of the gestures is the show all tabs on safari.
With in the last four years that i have owned this laptop Apple has needed to change the battery twice, the motherboard, charger, and charging port. so is it even worth fixing without any applecare left or is it time for a new one?
Nope, don't bother fixing it without applecare. I can identify the issue though. Most likely water or conductive fluid got spilled into the trackpad backplate, making the sensors go haywire due to the conductance material running all over them. Time for a better and more powerful laptop(I won't advise you on which one to buy so look it up).
