[SOLVED] Macbook Pro USB problems!?
Revsn
Commendable
Jul 29, 2016
21
Hey forum,
My friend has a pretty old macbook pro and has been having an issue with the USB ports for awhile now. When he turns on his Macbook with his mouse plugged in, it works fine with no problems. But after a bit when he wants to plug in a controller into the same USB port, the port doesn't work after he unplugs his mouse. I don't know if this is a board issue or a simple fix, because I don't know a ton about Mac's. But apparently restarting his Mac fixes the problem everytime. You guys can probably see how that can get annoying when you wanna switch games or something after a bit.
Thanks for your time,
Zach H.
Most likely a board issue, but I would suggest getting some 90% alcohol and a tooth brush. With the Mac powered off... try cleaning the ports. Wait until it's thoroughly dried before using again.
