Greetings,
I would kindly like to request some help with installing some drivers on a machine with no OS.
I have a desktop with the following configuration:
Super Micro Computer's X10DAC motherboard with Dual Xeon E5-2637 V2Processors, 15MB Cache
nVidia Quadro K2000 with 2GB GDDR5 SDRAM memory
256GB SSD Drive for the OS
LSI 3008-IR SAS Controller with 4 10K RPM SAS Drives
However the manufacturer did not install an OS or any drivers.
I at the very least I need to install the LAN drivers so that I can image the machine from the Network to Windows 7 using Microsoft MDT process and PE boot media.
I would kindly like to request some assistance on how to install the LAN Drivers (which I have obtained from Super Micro Computer's website; perhaps using a flash drive and some free tools like Knoppix Live CD). Right now the machine is not assigning an IP when I run ip config from Command prompt.
Any help would be greatly appreciated.
Thank you,
Sayeed
P.S. does any one know if the LSI 3008-IR is compatible with Microsoft bitlocker, The SAS Drives need to be configured with RAID 10.
Thank you,
Sayeed
