Mad Dog USB DVD burner not recognized
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hello,
I purchased a Mad Dog MegaStor 7-in-1 DVD burner and am having problems
getting xp to recognize it. The burner is brand new (i.e. its not an
old product I'm just now installing). It has its own power supply and
when I connect it I see the dialog popup about new hardware found. It
finishes installing and that's it. I've tried re-booting (hard and
soft) and still have the same problem.
When I first looked at the device manager it gave me a code 10 (device
can not start) under the USB controllers section. This error appears
intermittently. It is also listed under disk drives as a USB 2.0
Storage Device. I can sort of understand that but I thought it should
be listed under the DVD/CD-ROM section.
When I look under disk management the drive is not listed. Its listed
in the device manager (saying that it is working properly) but not under
disk management.
I've tried Mad Dogs site and searching newsgroups for info but I can't
seem to find a solution with something I have not tried. I have Windows
XP SP2 and everything else is the latest or has been updated (dell
inspiron 9100 laptop).
Does anyone have any solutions for me? Like I said the device manager
says everything is fine but the drive is not recognized under disk
management or windows explorer. I'd really like to get this drive to
work. I'd hate to purchase another unit and only have the same problem.
I've read where other people have problems getting xp to recognize
their ext hd's but have not read when their solutions were.
Thanks for your help!
Dave.
G
Guest
Guest
I also purchased this Mad Dog burner and the exact same problem is happening
to me. I plan on contacting Mad Dog customer service about this Monday. I
will post any info that I get but if anyone else has any suggestions please
respond. Thanks
Mike
"Dave Broer" wrote:
> Hello,
> disk management.
> Dave.
G
Guest
Guest
I talked to the tech support of Mad Dog and the tech support of Micro
Center(where I purchased it). They both decided that it was a bad drive so I
exchanged it for a new one and it worked as advertised with none of the
issues that I ran into with the first one. Hope this helps
Mike Mann
"Dave Broer" wrote:
> Hello,
> disk management.
> Dave.
G
Guest
Guest
I just installed one here on XP pro, working fine.
Make sure you install the driver CD before you connect and power up the
drive.
Nicely working unit, burns fast :)
