i've just finished a build with the msi mag b650m mortar wifi and everything is runnning smooth.
i've installed windows and everything else, but i have this issue.
when the pc ask for a restart or i try to restart the pc, it won't restart and the debug LED of the DRAM lights on, so i have to use the power button to shut down and restart manually my pc. i don't understand what's going on.
the bios is the stock version of the motherboard so maybe needs an update.
i have yet to try to test a single ram stick, maybe it's a faulty ram stick causing the problem.
does anyone have or had the same problem and have a solution to share or someone has an idea of how to fix this issue?
I've noticed in Bios that the ram was at 1.1v and I tried to put at 1.2 v and now I can exit from Bios without having to manually reboot the pc.
Yet I can't reboot through windows
My system:
MSI MAG B650M MORTAR WIFI
AMD Ryzen 5 7600
2x16 gb DDR5-6200 Viper Patriot
AMD Radeon Rx 6750 xt
Bios version: E7D76AMS.A10
Bios build date:19/10/2022
My system:
AMD Ryzen 5 7600
