J Jade_3 Commendable Feb 20, 2016 1 0 1,510 Feb 20, 2016 #1 What may be the problem with my epson l210, when I print a magenta and cyan the print out would be a royal blue and a red color?. so If I tried pink, the output seems to be a redish in color.Pls need your help.
Solution Ralston18 Feb 20, 2016 Possibly an ink cartridge getting low. Maybe a nozzle clogging. Clean the print heads per the manual and try again. Print a test page to see if everything is correct.
Ralston18 Titan Moderator Oct 11, 2014 39,390 4,367 146,290 Feb 20, 2016 Solution #2 Possibly an ink cartridge getting low. Maybe a nozzle clogging. Clean the print heads per the manual and try again. Print a test page to see if everything is correct. Upvote 0 Downvote Solution
