Archived from groups: alt.comp.hardware.pc-homebuilt (
More info?)
On Fri, 02 Jul 2004 06:23:06 -0700, Ken K wrote:
> Well, you raise an interesting point. Frankly, I have not investigated
> using Athlon chips since I looked at them a couple of years ago and I
> saw that they ran so hot that one needed to purchase a mini-air
> conditioner in order to keep them to a reasonable temperature. I would
> not mind investigating the issue further (I have no objection to getting
> more for my money); I assume that I must learn a bit more about memory
> combinations, etc. with them. I have no desire to overclock and I
> thought that Athlon chips were popular most amongst people who wanted to
> push their systems to the limits of failure.
The heat issue, while overstated, was more with the Tbird line of cpu's.
There's been several new cores since then and it's not an issue. An $8
cooler will cool any of the AND cpu's, even overclocked. the reason they
were popular two fold. First, they were a lot cheaper than comparable
Intel cpu's and they would also overclock very well for even more value.
> So plese begin my education: what is the main difference between the
> Athlon and Intel cpu's; it is mainly the price/value ratio?
Price vs. performance.
> Which Athlon cpu's represent the best bang for the buck presently?
Not overclocking, that's hard to say, but in general, any of the ones
under $80.
> Do I have to look at memory requirements any differently?
PC3200 will work with any of them. Some will work with PC2100.
> Which chipsets are the present darlings? which motherboards?
Any of the newer chipsets should be fine, Nvidia being the favorite among
overclockers because of the PCI/AGP lock. It all depends on what you want.
Personally, I like SIS, and that's all I have now. Thye're cheap and close
to the top on perfomance. The K7S8XE+ would be a good choice with SIS.
First you need to determine how much money you want to spend. Then see
what you can get for it. If moneys not an issue, then I could suggest the
best around and you'd be happy, while maybe spending twice as much as you
needed to.
Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
http://mysite.verizon.net/res0exft/cpu.htm
