maintenance on a water cooled system?
maverick7
920
well i just wanted to know really what is involved in maintaining your system? replacing the tubes, liquid?? etc etc?? i really have no idea so can someone let me know what i should be doing, thanks.
yes i suppose your quite right then, that if everything is sound when i first set it up, there really should be no leak problems at all..
So which would you personally suggest for a coolant?
ok this product says it is better than water wetter, should i trust it??
D-TEK Customs Supercool Anti Corrosion Water Additive for Water Cooling Systems
its $6.75 a bottle
and this is the description: "This is the ultimate Water corrosion and additive. Supercool Fortifies all coolant to wet heat transfer surfaces by 50%. Provides superior corrosion protection and for all types of metals. One bottle treats a typical watercooling system. Will meet and exceed Water Wetter and Purple Ice!"
also what about PT Nuke??
and at what ratio do i use water wetter if i choose to go with that
