Ok so I am brand new to buiding a computer, and I need a bit of assistance. Right now I have the following:
750W PSU
ASUS Crosshair IV Extreme
AMD Phenom II x6 1090T
2x6GB Corsair Dominator GT (2000MHz PC16000)
As well as those, I have additional stuff to plug in but it is not as important. So basically my problem is that I cannot turn my computer on. When I plug my PSU in, the LED's on the Motherboard light up, but when I try to power the computer on nothing happens.
The first time I try to turn my computer on after I plug it into the wall the fans budge to show that power does exist, but that is it. They barely move, fall right back into place, and then nothing happens with my system.
I went through the steps of unplugging 1 thing at a time till I had nothing left but the RAM, PSU, and CPU plugged into the Motherboard, however that did not solve anything.
I know the PSU works because I JUST took it out of another computer and it worked in that. Is there anything I missed that I should be doing? I cleared the CMOS, and I have tried more than a dozen time replugging things in. It is all plugged into the correct spots, and plugged in securely, but nothing happens, and I even tried plugging in the EZ_PLUG?_1 & 2 to see if the extra power could do anything but I have had no luck.
Thank you in advance for your responses,
Dawgs9604
750W PSU
Dawgs9604
