Major Problem :(
GreenGoblin
61
Hey all, I've got a major problem I got 8040 on 3Dmark 2001SE with a RADEON 9800PRO!!!!!
The thing is that I have 2 of these Radeons 9800pro ( one for me and one for my gf) I tested them both on the same rig and puled of the same resaults.
My rig is
Motherboard: Gigabyte GA-7S748L SIS 748
CPU: AMD 1900XP
MEMORY: 512 PC2100.
Using Catalyst 4.4
I wanted to check how this mother board works without the radeon, i took an old ati rage card, I ran CS on SOFTWARE rendering and got the same resaults as with the 9800pro, i mean the same problems, i got Frame drops in cs the same was at 3dmark2001se with the radeon ( normaly with my other mother board the GA 7va with the VIA 400 KT with software rendering on cs never had these problems) So I think its the SIS748 chipset which is pulling back the performance and not the Radeon9800pro :/, any tips guys?
You confirmed that your FSB and AGP settings are correct yet?
Wanted: Wet Nurse needed for 25 yr old male. Payment in bed credits.
Are you sure you didn't get the Radeon 9800SE by mistake? Did you load the SiS chipset drivers?
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Its 9800pro, it has no problems I"ve tested it on other systems and it worked great.
I'ts the Montherboard it self because i used software rendering and it did the same drastic frame drops as on my similar via 400KT rig I do not experience these problems :/
I'll try to uninstall the drivers again 🙁 if it wont help i"ll probably format
