Makes any difference between 1 fan or 2 fans? Can you Help me?
soloracingrivals
22
Hello,
I just received a pic of the pc i selected to be build.
I was concerning because which i thought i will receive it was a GTX 1060 dual fan but they built it with 1 fan
Is MSI GTX 1060 single fan 6gb
Make any difference? Performance?
Also, the GFX they sending me supposedly comes with VR already.
That is my pc in the picture below.
Feel free to comment
https://ibb.co/f3AD8w
Hello
looks ok to me, not a full board, so the fan covers most of it., though it is slightly deeper. so i expect it will also require you to have some good fans in/on your case.
SoggyTissue
Estimable
Jun 27, 2017
1,029
generally, more fans will result in a more even temperature cooling over the entire board. 1 fan limits the area to which it can cool .... the heat pipe/fins template ofc helps spread the heat too.
so in reality, the only real difference will be the heat spots on your card .... less with more fans (generally). this is important for the longevity and stability of your card. its not desasterous, but it may affect the lifespan you can expect.
soloracingrivals
22
How long can be that GFX??
I just planing to play league of legends, forza, GTA couple simulators
SoggyTissue
Estimable
Jun 27, 2017
1,029
i cant tell you how long or short the life span of a graphics card will be, it depends on how they modeled the cooling, its original life expectency etc.
it wont burn out in the next year or 2, but it probably wont last more than 3+ years (cause companies will expect you to replace your old stuff every 3-4 years or so anyway).
soloracingrivals
22
I finally call them, and they put this one in my pc
https://www.msi.com/Graphics-card/GeForce-GTX-1060-AERO-ITX-6G-OC.html
What do you think?
soloracingrivals
22
Yeah i think i have 2 with the case i chose. Otherwise i have to buy more i think.
Case: X-2 Tempered Glass
Motherboard: ASUS PRIME Z370-P ATX
Processor: Intel® Six Core™ i5-8400 Processor
Memory: Xidax Extreme DDR4 2666MHz Memory - 8gb
Power Supply: Corsair 550W Power Supply
Wireless: TP-Link Wireless Dual Band PCI Express Adapter
Graphics Card: - MSI GeForce GTX 1060 6GB Aero ITX
SSD: - Samsung 850 Pro 256GB SSD
Sleeving Red Uni-Sleeved Cables
CPU Cooling: Asetek 550LC CPU Cooler
What do you think about this build? that what i order,
Gaming Monitor 24' Full HD Led 1080 CTL
soloracingrivals
22
This one
G.SKILL Ripjaws V Series 8GB (2 x 4GB) 288-Pin DDR4 SDRAM DDR4 2666 (PC4 21300)
What do you think for the whole pc?
soloracingrivals
22
I think, i havent receive my pc yet until monday or tuesday.
Mmm also the room temperature it has to affect something in the desktop temperature?
SoggyTissue
Estimable
Jun 27, 2017
1,029
yes, ambient air temps will affect the cooling of fans, which is why some people opt for liquid cooling. but unless youre going to overclock, use a ryzen, place it next to your heater; theres no real danger of overheating.
soloracingrivals
22
Nice cuz where i live i have the A/C and room temperature no over 73C.
I am not planing over clock, i just planing to enjoy playing couple games
Thanks
