Making A New PC Build! (General Questions)
Yoface
60
I am upgrading my PC! (PC Specs: (I bought a prebuilt, and then upgraded) Graphics Card: GTX 650 (SuperClocked) Processor: AMD APU 3850 Power Supply: 750 watt ThermalTake Ram: 8 gigs of a random brand Hard Drive(s): 465 Internal, 1TB External)
I am planning on upgrading to this: http://pcpartpicker.com/user/RobotCactus/saved/Qc9tt6
As you can see, the HardDrive and the PSU are missing, I am planning on transfering those.
I mainly stream and do gaming. Tell me your thoughts!
Get a gigabyte 970a ud3p. It's cheaper.
With the money saved, you could get a r9 280.
You also have enough money to add on a CM Hyper 212 evo for overclocking if you're going to do that.
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($149.98 @ OutletPC)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard ($69.99 @ Newegg)
Memory: Team Vulcan 8GB (2 x 4GB) DDR3-1600 Memory ($68.99 @ Newegg)
Video Card: XFX Radeon R9 280 3GB Double Dissipation Video Card ($214.99 @ NCIX US)
Case: Cooler Master HAF 912 ATX Mid Tower Case ($49.99 @ Micro Center)
Optical Drive: LG GH24NSB0 DVD/CD...
Optical Drive: LG GH24NSB0 DVD/CD Writer ($13.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($89.98 @ OutletPC)
Total: $657.91
This build right here can hold up to Livestreaming?
I stream occasionally @720p 60fps 3500bit rate with minimal problems with a 8350 + r9 270. Dropped frames that I get are usually from my connection being a bit wonky at times.
As for the cpu you selected, I suggest getting an aftermarket cooler and overclocking.
The motherboard is a good motherboard for overclocking. If you don't really wanna overclock much, at least get it to 4ghz to match the fx 8350.
So which power supply/harddrive would you recommend instead?
