Hello,
we just recently got a second internet at our house and today i decided to get it working. I have 1 on board LAN port, and since i will be changing between the 2 connections quite often, i figured i should install another network card (since i had one in an old pc). I installed the card and started my pc. The lights on the card started flashing, and Windows also recognized that there was indeed a card connected. The problem is that it doesn't have a driver, and so the only way i can even see the card is in device manager. I managed to find drivers for the card, but they are extremely old (like the card) and i cant just press install (and i cant manually update it, since the drivers are for win xp). I dont know how to install the drivers, and i hope you can help me with that. I was wondering if i could use a virtual machine xp and install the drivers?! (just a thought that crossed my mind.
This is the driver i was trying to install: http://download.driverguide.com/driver/40-0483-001/3Com/d1786398.html
(im using windows 10)
Cheers, MrHaamu
Cheers, MrHaamu
