[SOLVED] Making new pc need little bit help about it
nabajoli
Commendable
Jan 19, 2018
22
Hello all making new pc im going to write the stuff i want to buy but i dont know this stuff gonna work together thats why im asking from here
CPU :
Amd Ryzen 7 3800X 3.9/4.5Ghz AM4
Motherboard :
MSI MB B360M Mortar Titanium Soket 1151 DDR4 2666 DVI VGA HDMI USB3.1 mATX
GPU :
Gigabyte AMD Radeon RX 5700XT Gaming OC 8GB
RAM :
CORSAIR 16GB (2x8GB) Vengeance DDR4 3200MHz CL16 RGB Pro Led
CASE :
Thermaltake View 27 600W 80+ PSU 4x120mm Fan
SSD:
Samsung 970 Evo Plus NVMe 500GB 3500MB/s-3300MB/s M.2 SSD
Do you guys think this computer im making will run smooth and without problem ? thanks for the answers.
Djoza
833
109
590
23
CPU :
Motherboard :
GPU :
RAM :
CASE :
SSD:
the mobo worries me.You ram wont work on 3200mhz.I would suggest either this:https://www.asus.com/Motherboards/ROG-Strix-X570-E-Gaming/
Or this:ASUS ROG Strix X470-F
I built played with your build a little bit:
The main things i changed are:
Added a liquid AIO
Different MOBO
Upped the ram capacity (2x16gb) and speed (3600Mhz)
Doubled the size of the m.2 ssd
I couldnt find the gpu so i suggest sticking with the gigabyte 5700XT
Different case cuz the other one honestly it was ugly and it had a psu.The psus that come with cases are ussually trash.
Switched the PSU
Added another case fan
Djoza
833
109
590
23
CPU :
Motherboard :
GPU :
RAM :
CASE :
SSD:
Added a liquid AIO
Different MOBO
Switched the PSU
