I need help choosing the right and budget friendly coolant for my loop.
I have all parts ready to build a loop. I can build with both soft and hard line tubing.
My loop is entirely with copper and brass components.
The only stone in my path is coolant. As per config estimated volume of water will be:
Radiator = 350 ml
Reservoir = 565 ml
Pipes/Tubing = 55 ml
CPU Block = 15ml
Total Volume = 985 ml
I can:
Also i'm in INDIA and not in US so getting a recommended biocide like Pt Nuke and Dead Water is not possible. There's no kill coil available here either.
I can get CuSO4[Copper Sulfate] in powdered raw form and make a 5% solution with DW, which is same as 'dead water' actually and i can buy it for cheap $2-3 any day thus not included above.
Some people might think it will be a bit of headache to "make all of it", for me It will be a fun experiment building a coolant and loop.
What you guys recommend.
UPDATE: So I have now about 50ml ethyl glycol + 750 ml Distilled Water, This is how it looks like:
Radiator = 350 ml
Reservoir = 565 ml
CPU Block = 15ml
I can:
- Buy a brand coolant about 2 Ltr for: $50 [3600 INR] or 1Ltr for $25 from here: https://mdcomputers.in/corsair-hydro-x-xl5-clear-cx-9060001-ww.html?search=coolant&category_id=0
- Make a coolant about 2-4 Ltr for: $14 [1000 INR] Ethylene Alcohol[170ml] + Distilled Water[DW ][1000ml]
- Make a coolant about 2-4 Ltr for: $10 [750 INR] with Ethylene glycol based coolant - Car Antifreeze coolant* [100ml] + Distilled Water[1000ml].
- Just Use distilled water 2 Ltr for: $5 [350 INR] and be done with it.
