Making RCA Switch Box (Soldering Question)
cydoc
I am curious if anyone knows where exactly I need to solder my wires on some RCA plugs for input and output. Thanks for any and all help!
I think your question is more about the circuit required. To take a single switchable channel as an example you'd need: three RCA/phono sockets and a switch.
Assuming the box provided screening and the phono socket was secured to the metal of the box via the (negative) body of the socket you could simply solder unscreened wire to the centre connector of the (incoming) phono socket and then via the switch to the two (outgoing) sockets -- the switch providing the alternate paths.
For such a project I would start with a multimeter and a couple of different switches which wil help you work out what switching you require -- and to trouble shoot the finished assembly.
Universal remote controllers are an advanced version of remote controllers. Typical remote controllers are designed to issue commands from a distance to a specific electronic apparatus.The journey with the universal remote control just doesn't stops there, but can continue with the up gradations that are required with the changing electronic devices.RCA Credit provides counseling for people with bad credit problems. Most of the time problems arising from bad credit stem from people's lack of discipline especially when it comes to spending.
Gold Contact Repair Kit
