Hopefully this is the correct section of the forum for my question. I have 2 Android devices, a Samsung tablet and an LG Leon Smartphone. I have installed CPU-Z on both devices. When the Samsung tablet is in nearly idle mode the clock speed of CPU 0 drops to 300 MHz and CPU 1-3 are parked, presumably to save battery power.
However on the LG Phone, the lowest clock speed is 800 MHz, on all four cores.
Both have the exact same Android Version 5.1.1. According to CPU-Z the clock speed range for the Samsung is 300 MHz - 1.19 GHZ. For the LG Leon it is 200 MHz - 1.21 GHz.
So my question is this: Is there a way to get into the operating system to make the LG Leon park some of the cores when the CPU load is very low, or to make the clock speed drop down to 200 MHz. Or are Android OS's "locked" to prevent people from screwing things up. If I can change the clock speed would this have a material difference on the power consumption?
