Manhattan Thermal Grease vs AVE Thermal Compound
ivanosky
43
Hi, I've been getting high temperatures on my CPU (Intel Core i5 3570k) so I will reapply thermal paste.
I live in Cuba and these are the only brands available here (Manhattan and AVE).
These are links to those products:
AVE: http://www.xsfans.com/index.php?main_page=product_info&products_id=90
Manhattan: http://www.manhattan-products.com/cpu-thermal-grease
In your opinion which one should I use?
I apologize for my english.
Thanks in advance.
I've just found another thermal grease the Evercool Sidewinder STC-01 is available here.
Sidewinder STC-01: http://www.evercool.com.tw/categories/global/accessory/peripherals/stc-01/sidewinder.html
What do you think of this one, compared to the others?
its not what you use so much as how you use it.properly applied i doubt you will get more than a degree or two difference in temps between any of the major brands.i use whatever is at my local computer store.
The evercool has better reviews than the other 2 you mentioned before. It's not artic silver but definitely better than the other 2 :)
Where did you find reviews about these brands? Because I've been googling a lot and haven't found any decent reviews of any of these brands. Could you please post the links to these reviews?
