Hi!
After adding 8gb memory stick i had many issues in a short period of time (3 days, about 8 windows crashes)
At the beggining i would like to sorry for my bad english, i hope you can help me anyway. Also i didnt know to post this in Windows 10 or Memory category.
Ok, i added 8GB RAM (Crucial 8GB DDR3L-1600 UDIMM
CT102464BD160B . My second stick is Elixir DDR3 8GB, 1600Mhz
11 CL. My first and second startup with new RAM stick was fine, at third time when i checked CPU-Z it was showing me nothing in memory tab (all was blank). Next time when i turned on my pc, nothing happend on screen (pc was working but there was no signal). I just removed my RAM stick and put him back again and it was all right. I came outside for about 20mins and when i came back i realised that there is again no signal, i restarted pc and checked system events, i found event "System Windows stopped working" inside there was note (here translated by me from PL to EN): "System restarted after errors detection procedure. Here is the results 0x0000007e (0xffffffff80000003, 0xfffff80040ee7c83, 0xfffff687b31b1878, 0xfffff687b31b10c0). Log is saved to C:\WINDOWS\MEMORY.DMP. Report ID: 00000000-0000-0000-0000-000000000000.". Next event was BSOD with ID: AV_nt!KiDeferredReadyThread
Here is the log:
Also i checked this MEMORY.DMP (but it looks like totally corrupted so its probably useless ), here is the logs:
Here im also posting quote from this bluescreen:
A problem has been detected and Windows has been shut down to prevent damage to your computer.
The problem seems to be caused by the following file:
ATTEMPTED_WRITE_TO_READONLY_MEMORY
My system also crashes every time when im leaving it on afk (its not crashing when game is turned on). Im just leaving it for example for 30mins and when im coming back there is no signal (also my keyboard and mouse lighting not work).
edit: i also forget to mention that after this error my system had problem with booting. There was message "Bootmgr image is corrupt. System cannot boot." but next time he started correctly.
My first thoughts was that something is wrong with auto screen turning off for energy saving (after 20mins), now im turned it off.
I tested my memory using Windows Memory Testing Tool (or something like that) and it found no errors.
07.05.2018: Tested crucial mem using memtest86, found no errors.
Later i changed RAM speed and voltage using BIOS (before was Auto). It resulted
with no more bluescreens in games but later i was unable to boot system (i was also
unable to get into bios (black screen after turning on pc). When system started,
bluescreen appeared and system got damaged (i had to use system rollback)
My specs:
Mobo: ASUS M5A78L-M LX3
CPU: AMD FX-8300
GPU: GTX 1060 3GB
RAM: Elixir DDR3 8GB, 1600Mhz 11 CL
Crucial 8GB DDR3 8GB 1600Mhz 11 CL (new one)
OS: Win10
I hope you can help me, this my first thread on this forum so tell me if you want more informations.
Thanks
Here is the log:
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck A, {ffffbe06fcf2f642, 2, 0, fffff801a1cd4e27}
Probably caused by : ntkrnlmp.exe ( nt!KiDeferredReadyThread+c7 )
Followup: MachineOwner
nt!KeBugCheckEx:
fffff801`a1d8b930 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffffe01`effb1610=000000000000000a
************* Path validation summary **************
Response Time (ms) Location
Deferred srv*
6: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: ffffbe06fcf2f642, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff801a1cd4e27, address which referenced memory
Debugging Details:
KEY_VALUES_STRING: 1
TIMELINE_ANALYSIS: 1
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 10.0.16299.371 (WinBuild.160101.0800)
SYSTEM_MANUFACTURER: System manufacturer
SYSTEM_PRODUCT_NAME: System Product Name
SYSTEM_SKU: To Be Filled By O.E.M.
SYSTEM_VERSION: System Version
BIOS_VENDOR: American Megatrends Inc.
BIOS_VERSION: 1201
BIOS_DATE: 04/19/2013
BASEBOARD_MANUFACTURER: ASUSTeK Computer INC.
BASEBOARD_PRODUCT: M5A78L-M LX3
BASEBOARD_VERSION: Rev X.0x
DUMP_TYPE: 2
BUGCHECK_P1: ffffbe06fcf2f642
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff801a1cd4e27
READ_ADDRESS: fffff801a2012380: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
ffffbe06fcf2f642
CURRENT_IRQL: 2
FAULTING_IP:
fffff801`a1cd4e27 0fb680c2050000 movzx eax,byte ptr [rax+5C2h]
CPU_COUNT: 8
CPU_MHZ: cf3
CPU_VENDOR: AuthenticAMD
CPU_FAMILY: 15
CPU_MODEL: 2
CPU_STEPPING: 0
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: AV
PROCESS_NAME: nvcontainer.exe
ANALYSIS_SESSION_HOST: DESKTOP-3VKSIRQ
ANALYSIS_SESSION_TIME: 05-06-2018 18:36:46.0789
ANALYSIS_VERSION: 10.0.17074.1002 amd64fre
TRAP_FRAME: fffffe01effb1750 -- (.trap 0xfffffe01effb1750)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=ffffbe06fcf2f080 rbx=0000000000000000 rcx=ffffd280f8f00180
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff801a1cd4e27 rsp=fffffe01effb18e0 rbp=fffffe01effb1960
r8=000000000000000f r9=0000000000000000 r10=fffff801a2149700
r11=ffffe28ab957b800 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
nt!KiDeferredReadyThread+0xc7:
fffff801`a1cd4e27 0fb680c2050000 movzx eax,byte ptr [rax+5C2h] ds:ffffbe06`fcf2f642=??
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff801a1d9dae9 to fffff801a1d8b930
STACK_TEXT:
fffffe01`effb1608 fffff801`a1d9dae9 : 00000000`0000000a ffffbe06`fcf2f642 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffffe01`effb1610 fffff801`a1d9a1fe : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffffe01`effb1750 fffff801`a1cd4e27 : 00000000`00000000 00000000`00000000 00000000`00000002 ffffd280`f8da9180 : nt!KiPageFault+0x47e
fffffe01`effb18e0 fffff801`a1cd4ac7 : ffffd280`f8f00180 fffff801`a210d8d0 fffffe01`00000000 fffff801`00000000 : nt!KiDeferredReadyThread+0xc7
fffffe01`effb19a0 fffff801`a1cd86c9 : ffffbe06`8643bfe0 00000000`00000000 00000000`00000000 00000000`00000001 : nt!KiExitDispatcher+0x117
fffffe01`effb1a10 fffff801`a2149823 : fffffe01`746c6644 00000000`1602f698 fffffe01`effb1b80 ffffbe06`8643bfe0 : nt!KeReleaseSemaphore+0x109
fffffe01`effb1a90 fffff801`a1d9d513 : ffffbe06`8a958080 00000000`10954ca0 00000000`1602f698 ffffbe06`86522001 : nt!NtReleaseSemaphore+0x93
fffffe01`effb1b00 00000000`71a31e5c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`1185f228 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x71a31e5c
THREAD_SHA1_HASH_MOD_FUNC: 87a90afd19e937ebbee48def4f5d3b7f5bfced69
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: ed496c94621f163febb4c253545a7e8adb4a1c92
THREAD_SHA1_HASH_MOD: cb5f414824c2521bcc505eaa03e92fa10922dad8
FOLLOWUP_IP:
FAULT_INSTR_CODE: c280b60f
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!KiDeferredReadyThread+c7
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 5abdad89
IMAGE_VERSION: 10.0.16299.371
STACK_COMMAND: .thread ; .cxr ; kb
BUCKET_ID_FUNC_OFFSET: c7
FAILURE_BUCKET_ID: AV_nt!KiDeferredReadyThread
PRIMARY_PROBLEM_CLASS: AV_nt!KiDeferredReadyThread
TARGET_TIME: 2018-05-05T11:08:44.000Z
OSBUILD: 16299
OSSERVICEPACK: 371
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 2018-03-30 05:22:49
BUILDDATESTAMP_STR: 160101.0800
BUILDLAB_STR: WinBuild
BUILDOSVER_STR: 10.0.16299.371
ANALYSIS_SESSION_ELAPSED_TIME: 1268
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:av_nt!kideferredreadythread
FAILURE_ID_HASH: {d70641df-b27f-49ce-f6c0-b234c7435b54}
nt!KeBugCheckEx:
Deferred srv*
6: kd> !analyze -v
Arguments:
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BIOS_VERSION: 1201
DUMP_TYPE: 2
BUGCHECK_P2: 2
BUGCHECK_P3: 0
ffffbe06fcf2f642
CURRENT_IRQL: 2
FAULTING_IP:
CPU_COUNT: 8
CPU_MHZ: cf3
CPU_FAMILY: 15
CPU_MODEL: 2
CPU_STEPPING: 0
BUGCHECK_STR: AV
STACK_TEXT:
FOLLOWUP_IP:
MODULE_NAME: nt
OSBUILD: 16299
OSSERVICEPACK: 371
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSNAME: Windows 10
OS_LOCALE:
USER_LCID: 0
ANALYSIS_SOURCE: KM
Symbol search path is: srv*
Executable search path is:
THIS DUMP FILE IS PARTIALLY CORRUPT.
KdDebuggerDataBlock is not present or unreadable.
Unable to read PsLoadedModuleList
KdDebuggerData.KernBase < SystemRangeStart
Windows 10 Kernel Version 16299 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0x00000000`00000000 PsLoadedModuleList = 0xfffff803`aebfd070
Debug session time: Sun May 6 15:31:01.081 2018 (UTC + 2:00)
System Uptime: 0 days 2:19:25.832
Loading Kernel Symbols
GetContextState failed, 0xD0000147
CS descriptor lookup failed
Unable to get program counter
Unable to get current machine context, NTSTATUS 0xC0000147
BugCheck BE, {ffffe30085559be0, 8a00000005100121, ffffdf03fefb1320, a}
***** Debugger could not find nt in module list, module list might be corrupt, error 0x80070057.
ReadControl failed - kernel symbols must be loaded first
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
WARNING: Unable to reset page directories
Deferred srv*
?: kd> !analyze -v
ATTEMPTED_WRITE_TO_READONLY_MEMORY (be)
An attempt was made to write to readonly memory. The guilty driver is on the
stack trace (and is typically the current instruction pointer).
When possible, the guilty driver's name (Unicode string) is printed on
the bugcheck screen and saved in KiBugCheckDriver.
Arguments:
Arg1: ffffe30085559be0, Virtual address for the attempted write.
Arg2: 8a00000005100121, PTE contents.
Arg3: ffffdf03fefb1320, (reserved)
Arg4: 000000000000000a, (reserved)
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 401
DUMP_TYPE: 1
BUGCHECK_P1: ffffe30085559be0
BUGCHECK_P2: 8a00000005100121
BUGCHECK_P3: ffffdf03fefb1320
BUGCHECK_P4: a
CPU_COUNT: 8
CPU_MHZ: 0
CPU_VENDOR:
CPU_FAMILY: 0
CPU_MODEL: 0
CPU_STEPPING: 0
DEFAULT_BUCKET_ID: CORRUPT_MODULELIST_0xBE
BUGCHECK_STR: 0xBE
ANALYSIS_SESSION_TIME: 05-06-2018 18:39:50.0119
STACK_TEXT:
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
PRIMARY_PROBLEM_CLASS: CORRUPT_MODULELIST_0xBE
FAILURE_BUCKET_ID: CORRUPT_MODULELIST_0xBE
TARGET_TIME: 2018-05-06T13:31:01.000Z
OSBUILD: 16299
OSSERVICEPACK: 0
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSNAME: Windows 10
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: unknown_date
ANALYSIS_SESSION_ELAPSED_TIME: 34
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:corrupt_modulelist_0xbe
FAILURE_ID_HASH: {b9ec5406-e1f1-d3be-f9c9-b5e8bd40d43d}
Machine Name:
Deferred srv*
?: kd> !analyze -v
Arguments:
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 401
DUMP_TYPE: 1
BUGCHECK_P4: a
CPU_COUNT: 8
CPU_MHZ: 0
CPU_VENDOR:
CPU_FAMILY: 0
CPU_MODEL: 0
CPU_STEPPING: 0
BUGCHECK_STR: 0xBE
STACK_TEXT:
OSBUILD: 16299
OSSERVICEPACK: 0
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSNAME: Windows 10
OS_LOCALE:
USER_LCID: 0
ANALYSIS_SOURCE: KM
My specs:
CPU: AMD FX-8300
GPU: GTX 1060 3GB
OS: Win10
Thanks
