Many problems booting linux from usb
smith_
83
Hello, i am new to this forum and very new to linux and a newbie to using a usb as a bootable device.
My OS is currently windows xp sp3 32bit.
I have been using universal usb installer, linux live usb creator, and unetbootin. My flash drive is an 8gb PNY (i think usb 2.0).
I have been trying to download a working linux distro with persistance on my usb, so that i can do my code assignments and compile them with linux.
My first attempt was cent os live cd; i was able to get it to boot, but with no persistance.
I decided to try another linux and i tried to do a manual format of the drive by erasing all the files....and i think i may have removed some important hidden folders from the usb itself. I ran the error checking tool for the usb volume, but there was no error so i proceeded.
Next i tried to boot mint linux and puppy linux after Cent OS but i got an error message ("boot error") when trying to boot the usb in bios. Just recently i tried ubuntu 12.4 desktop i386 and was able to get to the purple ubuntu menu with options: (install, try without installing and etc). I tried all the options but was given the error message "unable to find a medium containing a live file system."
Why (depending on the linux distro and the usb creator i use) does my usb shows up in different sections of my bios boot options -> (when i press F12).
Also, i have been testing the usb on my sisters windows 7 laptop alongside my desktop; and found that some of the linux distros would boot up further than on my desktop.
Any help with this problem or ideas on a lightweight linux to use would be appreciated!
-Aaron
smith_
83
The usb is formated to fat 32 and i have set the persistance; still getting boot errors.
I was able to boot linux 9.10 dekstop i386 to the menu screen last night...but then i got this repeating error message after some time of loading.
"end_request: I/O error, dev fd0, sector 0
Buffer I/O error on device fd0, Logical block 0"
stillblue
1,163
177
A live CD won't have a persistence file because it's not rewritable. What is on your or your sisters hard drive is unimportant as the hard drive is not being used to start the computer. It sounds to me that flash has a problem and you should try with another. Fyi you didn't erase important files ,the installer puts everything it needs onto the flash .
smith_
83
1)Ubuntu 9.10-desktop-i386.iso is a live cd?
2)During the boot it mentions casper.rw, isn't that the persistance file?
And i have a different usb (sandisk cruzer) that i could try also, I'm just confused to what this error message means because i want to stay with this linux distribution.
stillblue
1,163
177
It probably is a live version. If you boot to it and the first choice is try Ubuntu then it is a live version. If the first option is install then it is not. It is 4 years old, it won't have many of the drivers that you may need that a newer version will have, is there a reason you want it?
smith_
83
The first option is to install and i want to use this linux because it is the only one that is working atm :( . Puppy linux wont even boot to menu.
stillblue
1,163
177
Puppy linux doesn't have a menu, it just starts running, are you sure you're burning the cd's/dvd's and not just copying to them? A very common mistake if you are.
You can't convert the disk you have to a live one but you can still download a live version of 9.10 at
http://old-releases.ubuntu.com/releases/9.10/
You want the desktop version, what you have is the alternate. I still think you'll find the problem is with the installation on the USB. Make double sure you've tried a different USB and a different installer.
smith_
83
I just tried my usb on my friends laptop and it worked 100% with persistance, which was frustrating. The problem is not with the usb. I think the problem might be my bios or something.
stillblue
1,163
177
Let's do this then. Tell us what the computer is, we don't know what your hardware is yet. ;)
While we look that over, reset your bios to it's default settings and give it a shot.
If I don't get right back it's because it's about time to shut down the generator and will be switching to phone, joys of the third world. I do however get to pick my own coffee and bananas.
8350rocks
Did you use something like pendrive installer to install the .iso onto the USB, or did you just copy/paste the files? That could be an issue...
Additionally...for lightweight, there are things out there like ArchLinux that basically require you to configure your install. There is also a guy here running alphaOS...which is really lightweight too.
smith_
83
--------[ EVEREST Home Edition (c) 2003-2005 Lavalys, Inc. ]------------------------------------------------------------
Version EVEREST v2.20.405
Homepage http://www.lavalys.com/
Report Type Report Wizard
Computer AARON-7DA3E14F1
Generator Owner
Operating System Microsoft Windows XP Home Edition 5.1.2600 (WinXP Retail)
Date 2013-10-28
Time 21:05
--------[ Summary ]-----------------------------------------------------------------------------------------------------
Computer:
OS Service Pack Service Pack 3
DirectX 4.09.00.0904 (DirectX 9.0c)
Computer Name AARON-7DA3E14F1
User Name Owner
Motherboard:
CPU Type Unknown, 2200 MHz (6 x 367)
Motherboard Name Unknown
Motherboard Chipset Unknown
System Memory 3328 MB
BIOS Type Award (02/24/09)
Display:
Video Adapter ATI Radeon HD 5500 Series (1024 MB)
Monitor Plug and Play Monitor [NoDB] (737317A539KS)
Multimedia:
Audio Adapter Realtek HD Audio output
Storage:
IDE Controller Standard Dual Channel PCI IDE Controller
Floppy Drive Floppy disk drive
Disk Drive WDC WD2500AAJS-75M0A0 (232 GB, IDE)
Disk Drive TEAC USB HS-SD Card USB Device
Disk Drive TEAC USB HS-MS Card USB Device
Disk Drive TEAC USB HS-xD/SM USB Device
Disk Drive TEAC USB HS-CF Card USB Device
Disk Drive pny USB 2.0 FD USB Device (7 GB, USB)
Optical Drive HL-DT-ST DVD+-RW GSA-H73N
SMART Hard Disks Status OK
Partitions:
H: (NTFS) 238409 MB (200892 MB free)
Input:
Keyboard HID Keyboard Device
Mouse HID-compliant mouse
Network:
Network Adapter Intel(R) 82562V-2 10/100 Network Connection (192.168.1.102)
Modem Conexant D850 56K V.9x DFVc Modem
Peripherals:
USB1 Controller Standard Universal PCI to USB Host Controller [NoDB]
USB2 Controller Standard Enhanced PCI to USB Host Controller [NoDB]
USB Device DeathAdder Mouse
USB Device USB Human Interface Device
USB Device USB Mass Storage Device
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type Award
Award BIOS Type Phoenix - AwardBIOS
Award BIOS Message (713D1P53) EVALUATION ROM - NOT FOR SALE
System BIOS Date 02/24/09
Video BIOS Date 08/31/10
BIOS Manufacturer:
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40
Problems & Suggestions:
Suggestion Are you looking for a BIOS Upgrade? Contact eSupport Today!
Suggestion System BIOS is more than 2 years old. Update it if necessary.
Suggestion Video BIOS is more than 2 years old. Update it if necessary.
--------[ Debug - Unknown ]---------------------------------------------------------------------------------------------
Monitor DELF003: Plug and Play Monitor [NoDB]
Motherboard (713D1P53) EVALUATION ROM - NOT FOR SALE
Motherboard 02/24/2009-1.0.18-6A79O009C-00
Motherboard DMIMOBO: Dell Inc. 0RY007
Motherboard DMISYS: Dell Inc. Inspiron 530
Optical HL-DT-ST DVD+-RW GSA-H73N
PCI/AGP 1002-68DA: ATI Radeon HD 5500 Series [NoDB]
PCI/AGP 1002-AA60: Microsoft UAA Bus Driver for High Definition Audio [NoDB]
PCI/AGP 8086-10C0: Intel(R) 82562V-2 10/100 Network Connection [NoDB]
PCI/AGP 8086-2916: PCI standard ISA bridge [NoDB]
PCI/AGP 8086-2920: Standard Dual Channel PCI IDE Controller [NoDB]
PCI/AGP 8086-2926: Standard Dual Channel PCI IDE Controller [NoDB]
PCI/AGP 8086-2930: SM Bus Controller [NoDB]
PCI/AGP 8086-2934: Standard Universal PCI to USB Host Controller [NoDB]
PCI/AGP 8086-2935: Standard Universal PCI to USB Host Controller [NoDB]
PCI/AGP 8086-2936: Standard Universal PCI to USB Host Controller [NoDB]
PCI/AGP 8086-2937: Standard Universal PCI to USB Host Controller [NoDB]
PCI/AGP 8086-2938: Standard Universal PCI to USB Host Controller [NoDB]
PCI/AGP 8086-2939: Standard Universal PCI to USB Host Controller [NoDB]
PCI/AGP 8086-293A: Standard Enhanced PCI to USB Host Controller [NoDB]
PCI/AGP 8086-293C: Standard Enhanced PCI to USB Host Controller [NoDB]
PCI/AGP 8086-293E: Microsoft UAA Bus Driver for High Definition Audio [NoDB]
PCI/AGP 8086-29C0: PCI standard host CPU bridge [NoDB]
PCI/AGP 8086-29C1: PCI standard PCI-to-PCI bridge [NoDB]
smith_
83
@8350rocks i have used many installers (see first post), and i did not copy and paste.
@stillblue i reset bios to default and still got boot errors . I also heard something about setting bios to AHCI mode, but there is no option that i can find..only RAID and IDE.
Boot errors after selecting run ubuntu from usb:
stillblue
1,163
177
Sorry, didn't catch this, fd0 means it's trying to load your floppy drive for some reason and you probably haven't got one. Disable floppy in the bios if it is there and if problem still persists edit syslinux.cfg on your flash.
Change where it says initrd=/casper/initrd.gz quiet splash
to
initrd=/casper/initrd.gz floppy.allowed_drive_mask=0 quiet splash
smith_
83
Is there an option to disable floppy drive in bios? Because i cant find it.Could the problem be that my usb is showing up as a hard disk?
Also, i'm having trouble finding "initrd=/casper/initrd.gz quiet splash." Is there a specific file i should look for?
smith_
83
The syslinux.cfg file only contains these lines..
"include menu.cfg default vesamenu.c32 prompt 0 timeout 300 gfxboot bootlogo"
Although the "text.cfg" file contains:
"default live label live menu label ^Run Ubuntu from this USB kernel /casper/vmlinuz append noprompt cdrom-detect/try-usb=true persistent file=/cdrom/preseed/ubuntu.seed boot=casper initrd=/casper/initrd.lz splash --
label live-installmenu label ^Install Ubuntu on a Hard Disk kernel /casper/vmlinuz append cdrom-detect/try-usb=true file=/cdrom/preseed/ubuntu.seed boot=casper only-ubiquity initrd=/casper/initrd.lz splash --label memtest menu label Test ^memory kernel /install/mt86plus label hd menu label ^Boot from first hard disk localboot 0x80"
smith_
83
Well, now we have the old good news bad news scenario...
Good news: Progress has been made. It looks like it boots up similar to when i tried it on my friends laptop. Every appears to be loading up fine.
Bad news: Boots up fine, but instead of going into the desktop it goes to a ubuntu loading screen with little bar going back and forth. Then it goes to a black loading screen with little spinning wheel of death (it might have crashed, i dont know i have been waiting for 30 + minutes)
To add insult to injury...when i press cntrl+alt+delete to restart... it starts doing a a normal shutdown (with files being loaded and saved into memory and everything) :??:
I can try looking at the splash screens after the boot menu and seeing what is up and post it here. But first I have to finish my project, so it might be a bit.
smith_
83
Alright, we are 90% of the way there. I am able to get to desktop with ubuntu 13.10 and have persistance! :)
I have 1 minor issue and 2 Questions..
i1) When i boot my usb, it goes to the ubuntu menu, then i select run from usb, then i get a loading screen, i press up to get out of it, a black screen pops up with alot of code that does like a checklist and error messages going through my pc's many usb ports and drive slots (floppy disk, cd, sd card, SM card, CF MD, Sd mini, MS duo) saying stuff like i/o error and such, until it reaches the usb (i presume) then it starts loading everything up fine and then everything is gold.
Q1) Is there some code that i can add to our initrd=/casper/initrd.lz code in syslinux to skip these checks?
Q2)Is there a way to make ubuntu run faster, (stalls a bit here and there and long boot, which is probably the usb's faulth)
stillblue
1,163
177
As a live version it has to go through those checks because you may put it in a different computer. Once installed on a hard drive it boots much faster. It also runs much much faster as well because the system isn't using so much ram. You could also install the lxde desktop which is much lighter and would be faster.
stillblue
1,163
177
I should point out that USB keys aren't really meant for this heavy a use, the constant back and forth. You really shouldn't keep anything you can't afford to lose there. Ie use one for the system and one for storage. Just until you decide that you must have your Linux and install it on a hard drive.
